pawan Posted July 31, 2019 Share Posted July 31, 2019 i bought a zooltro gas geyser. it only gives me hot water for 2 minutes or less. can anyone help please. Quote Link to comment Share on other sites More sharing options...
Jaco De Jongh Posted July 31, 2019 Share Posted July 31, 2019 1 hour ago, pawan said: i bought a zooltro gas geyser. it only gives me hot water for 2 minutes or less. can anyone help please. Gas geyzers are very sesitive to water flow. You have to buy one for a specific required flow. Normaly one would first measure the water flow on the taps where you want the hot water and then buy a geyser to match that. Or at least that is what I was taught and did when i bought mine. I can run my tap for an hour and have hot water. My brother in law on the other hand just bought one he liked. You can not shower for more that 2 minuts and then the water is cold. Have to close the tap and reopen it for another 2 minutes of hot water. We had to restrict the flow with a valve to give better resuls and loger hot water use. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 31, 2019 Share Posted July 31, 2019 1 hour ago, Jaco de Jongh said: Gas geyzers are very sesitive to water flow. And there I learn something new. Baie dankie, because I was "sniffing" around getting gas geysers at one point, and would have seen me arse. Quote Link to comment Share on other sites More sharing options...
Jaco De Jongh Posted July 31, 2019 Share Posted July 31, 2019 8 minutes ago, The Terrible Triplett said: And there I learn something new. The top of the range brands are better designed and a bit more tolarent to waterflow variations, but those models at the local gas shop and builders warehouse... well there you must have a prety good idea of what you need to make it work. Quote Link to comment Share on other sites More sharing options...
