clive18 Posted August 4, 2019 Share Posted August 4, 2019 Hi I am hoping someone may know the reason from the infinisolar 3kw inverter giving the error code "OT". Its beeping constantly, but still seems to be running. This error code is not in the manual. Thanks in advance Clive Quote Link to comment Share on other sites More sharing options...
Youda Posted August 4, 2019 Share Posted August 4, 2019 InfiniSolar can beep even if there's nothing really wrong. For example, depending on the configuration, it will beep if it's running from batteries while AC grid is disconnected. Same like UPS. "OT" code sounds strange, because all the codes are numbers normally - can you take a photo of the display? BTW - I would run SolarPower on the laptop and connect it to the inverter as the error codes are being shown in plaintext in this application. Quote Link to comment Share on other sites More sharing options...
clive18 Posted August 5, 2019 Author Share Posted August 5, 2019 Hi Youda Thanks for your response. I have uploaded a picture of the error code. Regards Clive Quote Link to comment Share on other sites More sharing options...
Coulomb Posted August 5, 2019 Share Posted August 5, 2019 21 hours ago, clive18 said: error code "OT" I would guess that this is a warning (not error; errors have a different icon) for Over Temperature. I agree it would be nice if the manual was clearer about the warnings. Youda 1 Quote Link to comment Share on other sites More sharing options...
Youda Posted August 5, 2019 Share Posted August 5, 2019 (edited) Hi @clive18 Coulomb nailed it - it really looks like the "Over Temperature" warning. According to the original InfiniSolar Plus 3K manual, the inverter should display "WR" for any warning event. This is very different from InfiniSolar Super 4K or Plus 5K and 10K, where every warning has it's unique number. Over Temperature is #12 then, see the last screenshot. But I know that since the original release, there was a hardware change in InfiniSolar Plus 3K to fix some issues with the product. So, it is very likely that together with the HW change there was a new FW released too. And this FW release changelog did not made it into the User Guide. That would explain why the inverter is now able to show these warning codes but it's not covered in the User Guide. I would suggest you to connect to the inverter via an USB/RS232 cable and SolarPower software, as the warning text will be logged in this tool. Old version of the SolarPower is on the CD that came with the inverter. A new version can be downloaded from here:http://www.ostrovni-elektrarny.cz/support/Voltronic/SolarPower_1.14SP2_windows.zip According to your display, the inverter is in bypass mode, and it's not making any AC power. It's just charging the batteries. It's highly probable that once you disconnect it from the AC, the loads will die. Warning page from InfiniSolar Plus 3K manual: The same page from InfiniSolar Super 4K manual: Edited August 5, 2019 by Youda Quote Link to comment Share on other sites More sharing options...
clive18 Posted August 9, 2019 Author Share Posted August 9, 2019 Hi. Thanks for everyone's help. I connected my laptop, and it is an "Over Temperature alarm". It says its at 90 degrees, which sounds too hot. The fans on the top seem to be off, which is worrying. I think I should have this seen to before something really melts down inside. Any recommended repairers out there? I am in Joburg. Thanks Clive Quote Link to comment Share on other sites More sharing options...
clive18 Posted August 13, 2019 Author Share Posted August 13, 2019 (edited) Hi. Just for sake of completeness, if anyone else is having this issue, I solved the problem by taking a vacuum cleaner and cleaning the 4 top vents of the inverter which were clogged up with a thick layer of dust. I thought there were 4 fans on the top, but they are just vents which were clogged up, and did not allow the hot air to escape. Thanks for everyone's help. Clive Edited August 13, 2019 by clive18 extra info Youda and Coulomb 2 Quote Link to comment Share on other sites More sharing options...
Youda Posted August 13, 2019 Share Posted August 13, 2019 (edited) Hi @clive18 thanks a lot for letting us know! Appreciated Edited August 13, 2019 by Youda Quote Link to comment Share on other sites More sharing options...
Ahmad Ali Posted January 9, 2020 Share Posted January 9, 2020 i have update the firmware infini 10kw with new virsion now i am facing error '50' Quote Link to comment Share on other sites More sharing options...
flltech Posted September 9 Share Posted September 9 On 2020/01/09 at 1:25 PM, Ahmad Ali said: i have update the firmware infini 10kw with new virsion now i am facing error '50' Did you ever find out what is Error 50 in this inverter and how did you resolve it? Quote Link to comment Share on other sites More sharing options...
