Solar system
Hie good people
If I charge 2  48VLEOCH batteries connected in parallel with a.c the inverter shows error 08 when the batteries are fully charged but the same inverter charges well with 2 Narada. What could be the cause of this in terms of different in specs of the two batteries
1 hour ago, Ndaba said:
Hie good people
LEOCH!!!!
possible stolen batteries so they don't want to be charged and neither should you.
8 hours ago, Ndaba said:
inverter shows error 08 when the batteries are fully charged but...
I don't know if this is your situation or not, but another forum user found error 08 to be caused by a loose neutral connection at the utility pole. I don't get how that causes high bus voltage, however. Perhaps you should check your neutral to earth voltage when using a moderate load like a kettle; I believe that it should be below about 2 VAC.
Edit: another thought. This post suggested that it may be due to the battery switching off at high battery voltages. Perhaps the bulk/absorb voltage (setting 26) is too high for the new battery? Keep in mind that Axperts will on occasion overshoot the set voltage for many seconds.
