INFINISOLAR warning #07
Blinkwater9
Yesterday, I had warning message #07 (AC INPUT ISLAND) on my INFINISOLAR 5kw inverter?
According to the user manual, this warning event refers to ISLAND DETECT, and the description says ISLAND OPERATION IS DETECTED?
No further information is provided? No recommended action is given either?
Has anyone had this warning message before? If so, can someone shed a little more light on this?
The inverter is set to NOT ALLOW feed into the grid, and an ANTI-ISLANDING protection device is installed. This unit has not detected and REVERSE POWERFLOW?
Hi @Blinkwater9
"Warning #7: AC input island"
To me that message says that the Public Grid is down and the inverter is operating in battery mode. Loads are ON, the energy is provided from the panels and the batteries. The Grid relay is disconnected, so no energy can flow into the Public Grid (and hurt ESKOM technicians that are working on the powerlines). Once the Public Grid will be back ON, it will take couple of minutes to reconnect, since the Infini will measure the grid values firts, then perform a safety delay and then it will close the grid relay again. Duration of the safety delay can be set here:
You should be able to simulate this warning flipping the AC input circuit breaker while inverter is operating.
I tried to simulate this myself, but since all my InfiniSolars are operating in the Off-Grid III Mode, it's generating the two different warnings in my setup:
Warning #2: Line voltage loss
Warning #4: Line frequency loss
Regs,
Youda
Edited by Youda
picture added
Hi Youda,
Sorry to hear of the personal issues? I hope you can work it all out?
I changed the WIDE AC INPUT RANGE to ON , which seems to reduce this warning message frequency.
I also contacted the inverter supplier for technical advice? They suggested changing GENERATOR AS AC SOURCE to ON?? Cant see how this could help, but I havent had the warning message since??
I must mention, that I am located in a small residential area, where there are a few large industrial consumers nearby. We tend to have large fluctuations in the pressure on our water supply, and I imagine, there could possibly be some fluctuations in the GRID AC supply specs that the inverter flagged as out of range?
Thanks for the time responding.
J
Hi @Blinkwater9
well, the quality of the grid could definitely be the root cause of the issue. All the hybrid inverters are monitoring incoming AC and once the quality falls out from the predefined range the hybrids are lowering their power or disconnecting from the grid completely. The actual parameters are part of the "Grid Standard", which can be selected here:
On top of that, you can lower the sensitivity by those two options that your installer told you.
And, if you really want, you can even put in your own values for voltage and frequency limits, as shown down below:
If you want to monitor the quality of the grid, take a look in "Data Log" from time to time and check "Grid Voltage" and "Grid Frequency" columns. In my case, both are zero, since my system is off-grid, of course:
Edited by Youda
  • 1 year later...
On 2019/11/03 at 4:13 PM, Youda said:
Hi @Blinkwater9
A bit off topic but logs in my inverter are stuck on 2018, there are no new events being reported in the logs, and when I try to delete the existing logs, it shows message "Operation Failure". How do I delete old logs and ensure new events are logged correctly?
  • 1 year later...
On 2021/02/26 at 4:01 PM, LionKing said:
Did you figure out the issue? My inverter has started doing the same, everyday from 5pm to 9pm
Hy, i have Same issue with my Infinity solar.
Is there Any solution?
Best regards Steve
I think its a grid issue, ours stopped happening after a month. Our installer said that the standard he had set VDE0126 is less forgiving then VDE4105 and that if it kept happening, I can switch to VD4105 and that will fix it. But i'm in Pakistan, not sure where you're from and whether VDE4105 is valid in your region.
Thank You for your quick reply, I am located in Germany, VDE4105 is valid and my inverter is using it.
I think the same with the grid. could be the onliest reason. My colleague is located 120km far from my home, got the same issues.
What could happen if i change to "Generator as AC Source"?
  • 4 months later...
Best regards Steve
My apologies for the delayed response? My issue is more than likely as a result of an unstable grid supply. The manufacturer suggested setting the GENERATOR POWER SOURCE to ON. This resloved my issue, and I havent seen any issues since, and the setting of GENERATOR to ON caused to other issues?
