self consumption settings for victron easy solar
i am new to the forum could you you please assist. i have a newly installed 3kVA victron easy solar inverter. how do i set it to prioritize solar PV to power th loads. i tried using Hub 1 assistant but it requires the country Grid code of which south africa is not on the given list for the easysolar.
King
Welcome to the forum King.
Please tel us how you have currently configured your system and what it is that you want to achieve. To run your system, you would only need to add the ESS assistant. That leaves with enough options to fine tune the rest.
