November 15, 20196 yr Hi I joined the forum recently and I'm impressed with the knowledge and setup that most of you have done. Currently I plan on just retro fitting my geysers to use EV tubes, and hopefully after saving in a year or two I plan to go full solar. I still need to cut a few trees in the process. Please help me for now with any JHB installers to retrofit geysers, my one set of geysers is currently running in series. Thanks
November 15, 20196 yr May I suggest that before making your decision you look at the Geyserwise PV system. They use PV panels directly connected to their system and a dual element. See https://www.geyserwise.com/ select Products and then PV water heating systems Edited November 15, 20196 yr by Richard Mackay
November 27, 20196 yr I got a question for my learned friends, I got spare solar power from my current system that I could use for the geyserwise solar solution, my question is how would I go about to connect the current system to the gyeserwise system if possible?
