SYC Posted November 17, 2019 Posted November 17, 2019 Hi Guyz, Need some advise on combining: 4 x Narada AGM 200ah +ha02 and 4 x Algrande Gel 200ah +ha02 to form 48v 400ah Bank Pros and cons? Quote
Crankshaft Posted November 18, 2019 Posted November 18, 2019 A second inverter / charger? Most folks would not recommend combining different batteries. SYC 1 Quote
phil.g00 Posted November 18, 2019 Posted November 18, 2019 Never used it and don't know it intimately, but there is something called a "Cyrix" battery combiner from Victon...... that may help. SYC 1 Quote
SYC Posted November 18, 2019 Author Posted November 18, 2019 59 minutes ago, Crankshaft said: A second inverter / charger? No intended all off 1 x Infini Solar super 4k Quote
SYC Posted November 18, 2019 Author Posted November 18, 2019 20 minutes ago, phil.g00 said: "Cyrix" battery combiner from Victon Only upto 24v Quote
phil.g00 Posted November 18, 2019 Posted November 18, 2019 4 minutes ago, sulyc said: Only upto 24v Nope, a 48V as well. https://www.victronenergy.com/upload/documents/Datasheet-Cyrix-i-400A-EN.pdf Quote
DeepBass9 Posted November 18, 2019 Posted November 18, 2019 So how would you use that? Run one string of batteries and then switch to the other? @sulyc, how are you going to charge these batteries? Are they very similar? Quote
SYC Posted November 18, 2019 Author Posted November 18, 2019 2 hours ago, DeepBass9 said: how are you going to charge these batteries? Are they very similar? From Solar with Infini. Yes Quote
SYC Posted November 18, 2019 Author Posted November 18, 2019 Herewith both batteries spec sheet GEL Battery 6CNFJ200 12V200Ah.pdf Narada-Batteries-12NDT200.pdf Quote
DeepBass9 Posted November 20, 2019 Posted November 20, 2019 Their specs and charging characterics are very similar, so they will probably be OK. However, subtle differences can make a big difference with batteries, you may find one type is doing all the heavy lifting, and the other string very little, similar to new and old batteries of the same type. In principle it is not a good idea, but maybe it all works out for you? SYC 1 Quote
