Hi, I am using Infini 10kW inverter at home. Usually batteries connected are charged through grid or PV or both. Can some one help me to know how to find out battery connected is being charged trough PV or Grid or both? Can I get data log directly from inverter?if yes then how and if not then what is best way to find out.
1) Install SolarPower application on your laptop and connect it to the InfiniSolar via RS232 or USB:
2) If you have "SNMP WebPro Card" in the "intelligent slot" of the Infini then you can connect to the inverter directly, via LAN and a Web browser.
Hi Youda,
Thanks indeed. But below parameters does not show power being used to charge battery from PV and Grid. Would youplease elaborate more?
Thakyou
