Kwagga Posted February 9, 2020 Share Posted February 9, 2020 On 2020/01/28 at 2:37 PM, Gerlach said: You will see one some of the screen shots shows capacity 60AH , then i founded the lifepo4 setting on the BMS and all the settings was adjusted correctly and batteries was fully charge at 119.1AH / 100% SOC. Can you supply me with link to the bms that you use Quote Link to comment Share on other sites More sharing options...
Gerlach Posted February 9, 2020 Author Share Posted February 9, 2020 @Kwagga hier is die link ZAR 801.03 24%OFF | Smart Bluetooth 7S-20S CELL Lifepo4 li-ion Battery protection Board BMS 400A 320A 300A 100A 80A PHONE APP 8S 10S 12S 13S 14S 16S https://s.click.aliexpress.com/e/_UeKHs 2de set of batteries is on there way to build a 2de bank. Other set is performing really good. JJS 1 Quote Link to comment Share on other sites More sharing options...
Kwagga Posted February 9, 2020 Share Posted February 9, 2020 1 hour ago, Gerlach said: @Kwagga hier is die link ZAR 801.03 24%OFF | Smart Bluetooth 7S-20S CELL Lifepo4 li-ion Battery protection Board BMS 400A 320A 300A 100A 80A PHONE APP 8S 10S 12S 13S 14S 16S https://s.click.aliexpress.com/e/_UeKHs 2de set of batteries is on there way to build a 2de bank. Other set is performing really good. Can you give me also the app in the play store. Seems I am going to replace my lead to lithium Thanks Quote Link to comment Share on other sites More sharing options...
Gerlach Posted February 9, 2020 Author Share Posted February 9, 2020 5 hours ago, Kwagga said: Can you give me also the app in the play store. Seems I am going to replace my lead to lithium Thanks It's a APK app, i founded via a Youtube video but the seller send me all the info via a msg that's on a cloud. I will send you the link. Quote Link to comment Share on other sites More sharing options...
Psion Posted February 10, 2020 Share Posted February 10, 2020 What would the benefit be of using these cells over other technologies, apart from the safety etc. As I see it you need 16 cells in series to make the "48V" but you still only have 120ah of capacity so it wouldn't last very long (dependent on load) or am I being daft and missing something? Quote Link to comment Share on other sites More sharing options...
Coulomb Posted February 10, 2020 Share Posted February 10, 2020 (edited) On 2020/02/10 at 7:29 PM, Psion said: As I see it you need 16 cells in series to make the "48V" but you still only have 120ah of capacity so it wouldn't last very long (dependent on load) or am I being daft and missing something? I think what you may be missing is this: for the same load, a nominally 48 V system uses a quarter the current that a nominally 12 V system does. You probably have an idea what 120 Ah at 12 V can power; with a 48 V 120 Ah system, you can power that same load 4 times as long. Probably longer, as your idea of 120 Ah is probably based on lead acid batteries, which have a Peukert effect (they don't provide as much energy at high loads as at lower loads); lithium chemistries don't exhibit this effect, or if they do it's very small. Think of a 12 V 10 A load; that's 120 W. A single 12 V 120 Ah battery could power that for about 12 hours (depending on Peukert effect, it may be a bit less). But then that's a 100% drain, not good for lead acid. So you only run it for 3 hours to preserve battery life. In a 48 V system, the load would be 2.5 A @ 48 V (still 2.5 x 48 = 120 W). So the set of 4 would last 12 hours. Now you switch to a lithium 48 V battery, still at 120 Ah. Now the 120 W load is only 2.5 A (48 V x 2.5 A = 120 W). So the lithium battery could power that for 120/2.5 = 48 hours. But again, that's a total discharge, also not good for the lithium battery. But unlike lead, you can discharge to 80% DOD (20% SOC), so that's 48 x 80% = 38 hours. 38 hours versus 12 hours [ edit: was 3 hours ]. Now do you see the benefit? There is also less voltage sag, higher charge efficiency, and so on. [ Edit: added lead acid on 48 V for fair comparison. Thanks, Ojeysky! ] Edited February 18, 2020 by Coulomb Fixed embarrassing error comparing 48 V with 12 V. Duh! Quote Link to comment Share on other sites More sharing options...
Psion Posted February 10, 2020 Share Posted February 10, 2020 @CoulombThank you very much that explains it perfectly! Quote Link to comment Share on other sites More sharing options...
Hennie65 Posted February 11, 2020 Share Posted February 11, 2020 Does anybody perhaps know where in SA one can buy a Lifepo4 charger to charge a 48V 16s 120Ah pack? I am referring to a regular 220V AC charger and not a solar charger. It seems they are only available from China and obviously nothing coming from there now. Or any other ideas will be much appreciated. Quote Link to comment Share on other sites More sharing options...
Gerlach Posted February 11, 2020 Author Share Posted February 11, 2020 @Hennie65 is there inverter connected to your 16s set? Quote Link to comment Share on other sites More sharing options...
Hennie65 Posted February 11, 2020 Share Posted February 11, 2020 I have batteries connected to my inverters but this is for a golfcart application and for somebody that does not have solar at all, thus needed to be charged frequently. Also bought the batteries from Bain but now charging is an issue. Power Supply only option I guess. Lots of them available on Aliexpress. Quote Link to comment Share on other sites More sharing options...
Hennie65 Posted February 11, 2020 Share Posted February 11, 2020 And I mean lots of chargers available on Ali... Quote Link to comment Share on other sites More sharing options...
P1000 Posted February 11, 2020 Share Posted February 11, 2020 52 minutes ago, Hennie65 said: And I mean lots of chargers available on Ali... Well, none of my packages have shipped from Ali in 2020, and it seems like it is going to be that way for at least another month... If they start shipping again after that, imagine the carnage at SAPO... Quote Link to comment Share on other sites More sharing options...
GVC Posted February 11, 2020 Share Posted February 11, 2020 Yep, same here...Still waiting for my stuff to shipped. Quote Link to comment Share on other sites More sharing options...
Gerlach Posted February 12, 2020 Author Share Posted February 12, 2020 my second batch is on it's way to build one more unit for my setup. waiting for the courier call. happy clap!!!! Quote Link to comment Share on other sites More sharing options...
Gerlach Posted February 12, 2020 Author Share Posted February 12, 2020 22 hours ago, Hennie65 said: I have batteries connected to my inverters but this is for a golfcart application and for somebody that does not have solar at all, thus needed to be charged frequently. Also bought the batteries from Bain but now charging is an issue. Power Supply only option I guess. Lots of them available on Aliexpress. Time to pump the Golfcart with some pannels on the roof and mppt on the that batteries hahahahah!! i spotted the other day a setup like this on n guys cart, and it works. Quote Link to comment Share on other sites More sharing options...
Gerlach Posted February 12, 2020 Author Share Posted February 12, 2020 21 hours ago, P1000 said: Well, none of my packages have shipped from Ali in 2020, and it seems like it is going to be that way for at least another month... If they start shipping again after that, imagine the carnage at SAPO... I was just lucky, some of stuff pitching up here and there after 3 months ordering. I guess SAPO had some time to sort out there 2 year back lock with now imports from China this 3 weeks. Quote Link to comment Share on other sites More sharing options...
Henniem1 Posted February 15, 2020 Share Posted February 15, 2020 On 2020/02/12 at 1:49 PM, Gerlach said: Time to pump the Golfcart with some pannels on the roof and mppt on the that batteries hahahahah!! i spotted the other day a setup like this on n guys cart, and it works. Have done that one on my Lead Acid cart, I am using it for over a year already, works perfectly! Quote Link to comment Share on other sites More sharing options...
___ Posted February 15, 2020 Share Posted February 15, 2020 14 minutes ago, Henniem1 said: cart I can imagine that working quite well in some areas! In December we spent a few days on a golf course on the South coast, I mean, one of those places that really lends credence to the "white monopoly capital" conspiracy theory. Sunshine all the time, and golf-carts all over, driven inside the estate, parked outside the club house... VisN 1 Quote Link to comment Share on other sites More sharing options...
Tsa Posted February 15, 2020 Share Posted February 15, 2020 Very cool! Would one be able to add this DIY battery pack to a current solution already running Pylontech or Dyness batteries? Quote Link to comment Share on other sites More sharing options...
badballie Posted February 16, 2020 Share Posted February 16, 2020 Just a quick question , i am building one of these DIY batteries , bought the batteries from Bain . I notice most of the people bind /tape the batteries together , would it not be better with a slight gap between the batteries like a thick double sided tape or some thing (3 or 4MM) ? Any one have an opinion on this as far as cooling goes . Quote Link to comment Share on other sites More sharing options...
Gerlach Posted February 16, 2020 Author Share Posted February 16, 2020 badballie 1 Quote Link to comment Share on other sites More sharing options...
JJS Posted February 16, 2020 Share Posted February 16, 2020 Nice info @Gerlach @Bain Viljoen Would it be a stupid question wrt eta for new stock and will you run them through a antivirus first? Quote Link to comment Share on other sites More sharing options...
Bain Viljoen Posted February 16, 2020 Share Posted February 16, 2020 @JJS Lol, I don't have any ETA as of yet, eta if i could order would be 6-8 weeks. The virus can survive 10 days without an host. the cells are allot longer on the water so don't stress lol Quote Link to comment Share on other sites More sharing options...
JJS Posted February 16, 2020 Share Posted February 16, 2020 2 minutes ago, Bain Viljoen said: @JJS Lol, I don't have any ETA as of yet, eta if i could order would be 6-8 weeks. The virus can survive 10 days without an host. the cells are allot longer on the water so don't stress lol Hahaha thanks @Bain Viljoen Quote Link to comment Share on other sites More sharing options...
ojeysky Posted February 18, 2020 Share Posted February 18, 2020 On 2020/02/10 at 10:59 AM, Coulomb said: I think what you may be missing is this: for the same load, a nominally 48 V system uses a quarter the current that a nominally 12 V system does. You probably have an idea what 120 Ah at 12 V can power; with a 48 V 120 Ah system, you can power that same load 4 times as long. Probably longer, as your idea of 120 Ah is probably based on lead acid batteries, which have a Peukert effect (they don't provide as much energy at high loads as at lower loads); lithium chemistries don't exhibit this effect, or if they do it's very small. Think of a 12 V 10 A load; that's 120 W. A single 12 V 120 Ah battery could power that for about 12 hours (depending on Peukert effect, it may be a bit less). But then that's a 100% drain, not good for lead acid. So you only run it for 3 hours to preserve battery life. Now you switch to a lithium 48 V battery, still at 120 Ah. Now the 120 W load is only 2.5 A (48 V x 2.5 A = 120 W). So the lithium battery could power that for 120/2.5 = 48 hours. But again, that's a total discharge, also not good for the lithium battery. But unlike lead, you can discharge to 80% DOD (20% SOC), so that's 48 x 80% = 38 hours. 38 hours versus 3 hours. Now do you see the benefit? There is also less voltage sag, higher charge efficiency, and so on. I think it will be 38hours versus 12hours since we should be working with a 48v Lead Acid as well, though it still does not remove the fact that lithium is much better and preferred. I have been using lithium for a month now and can say the experience is quite better....just like you noted, it reacts better to high load (high current draw) Quote Link to comment Share on other sites More sharing options...
