Vp-3000 inverter Ac charge
Moallam
Can you measure around 230 VAC at the AC-in terminals?
3 kW models have a separate battery charger, so they may behave a bit different to the 5 kVA models that I'm familiar with. But it seems to me that if AC-in is present, the icon should at least be present. If the quality is considered bad, I think it should flash the icon, as long as you have at least 80 VAC or so.
Spelling
3 kW models have a separate battery chsrger, so they may behave a bit different to the 5 kVA models that I'm familiar with. But it seems to me that if AC-in is present, the icon should at least be present. If the quality is considered bad, I think it should flash the icon, as long as you have at least 80 VAC or so.
@Coulomb
Thaks for your response.
I did the measurement and it was 230vac, but the icon does not appear.
