___ Posted May 13, 2020 Share Posted May 13, 2020 8 minutes ago, Gerrie said: with your phone via sonoff With a Victron system there would be little reason to do that. The changeover is to move your loads over to the grid because you need to turn the inverter off, do some kind of maintenance, and/or firmware updates. Oh, and because Cape Town wants to see it on the diagram. During normal operation -- because it is a hybrid inverter -- you can just instruct the inverter to take more power from the grid. And this you can also do with your phone Gerrie 1 Quote Link to comment Share on other sites More sharing options...
Tariq Posted May 13, 2020 Share Posted May 13, 2020 Have thought about using Sonoff’s for the geyser/pool pump instead of the cbi timers, problem is when it comes to electrical/mechanical stuff , I can hold my own, but when it comes to computers, I am still at the hunt and peck stage. Tariq Gerrie 1 Quote Link to comment Share on other sites More sharing options...
Tariq Posted May 13, 2020 Share Posted May 13, 2020 (edited) ACFrOgDaSOQJu7oUEzNruWui_MQjs7bd1z-caQ3XdyLKs9gD0_WQyTRfmjugmJJ_t7tJIs9tHy68iB1GlrmBXEPxz71OjMObDx7GjvG82pvUH53CDrShVXC6fyscrWqvmyihpjHwZCTSac1SFzjb.pdfACFrOgDaSOQJu7oUEzNruWui_MQjs7bd1z-caQ3XdyLKs9gD0_WQyTRfmjugmJJ_t7tJIs9tHy68iB1GlrmBXEPxz71OjMObDx7GjvG82pvUH53CDrShVXC6fyscrWqvmyihpjHwZCTSac1SFzjb.pdf Edited May 13, 2020 by Tariq Any idea as to difference between the top and bottom center points Quote Link to comment Share on other sites More sharing options...
Gerrie Posted May 13, 2020 Share Posted May 13, 2020 31 minutes ago, Tariq said: Any idea as to difference between the top and bottom center points Only difference seems to be the 25A to 40A has numbers at contacts instead of the L & GN like on 63A units Quote Link to comment Share on other sites More sharing options...
Gerrie Posted May 13, 2020 Share Posted May 13, 2020 (edited) 37 minutes ago, Tariq said: Edited May 13, 2020 by Gerrie Message doubled Quote Link to comment Share on other sites More sharing options...
Tariq Posted May 14, 2020 Share Posted May 14, 2020 Ok, ending up with a SFT440 priced at R726 ex vat, instead of two SFT240’s Tariq Quote Link to comment Share on other sites More sharing options...
Zapnologics Posted May 28, 2022 Share Posted May 28, 2022 Thanks for this info, I think I am going to go with two change over switches, so that I can individually control the ac input, You could direct the output load to use mains, while still having the input load charge the batteries or do firmware upgrade on the Mp2?. So essential 1 2P change over on ACIN and another 2P change over on ACOUT Quote Link to comment Share on other sites More sharing options...
