BMV 702 too fast to 100% SOC
Hey guys
My BMV SOC is jumping way too fast to 100% SOC.
This seems to happen on the absorb stage of charging whenever I look away.
When they are only drained a little like 95% SOC it does look like it's going to 100% slower.
I have the trojan T105RE's 48v Bank
225aH
Charger set to the following
Max Charger current: 20A
Bulk charge: 56.4v
Float: 52.8v
On the BMV settings
Setting 02 Charged Voltage: 52.6v
Setting 03 Tail Current: 4% (default)
Setting 04 Charged detection time: 5min (default 3min)
I suspect the problem is the tail current.
Should I lower this to 1% or maybe even 0.9%
Thys
Hi Thys
Unfortunately you have to fiddle.
Your charged voltage looks fine
Tail current looks high Mine is set on 2.8% . If I set it on 2.7%  it never goes to 100%.
Charged detection 10 min and I am contemplating moving it higher.
MY BMV still goes to 100% too early but not by much,
Hi Thys
It is a process of fiddling. I am nearly there but have got involved in a myriad of other things - life I suppose!
Yeah tell me about it have 3 panels waiting to be mounted, still need to build the brackets and rails for them
As I recall you can sync it manually, an done you've done that it should be more accurate for a while? Also, the timeout should be set to at least 7 minutes if I recall the Victron training stuff correctly, possibly even longer.
