viceroy Posted January 10, 2020 Share Posted January 10, 2020 This afternoon, I purchased ICC Pi V2, rushed home in order to install, and then remembered my Axpert MKS 4kW has a serial port... How do I connect it to the Pi? With the old AICC on PC, I used a serial to USB adaptor, but this doesn't work on the Pi. Any advice on what device might work? Quote Link to comment Share on other sites More sharing options...
SYC Posted January 10, 2020 Share Posted January 10, 2020 USB printer cable for most and for New Axpert King Hope this helps Quote Link to comment Share on other sites More sharing options...
viceroy Posted January 10, 2020 Author Share Posted January 10, 2020 Thanks for the response @Quat Allah Al Shams, but doesn't really help. As mentioned, my Axpert has no usb port at all, only a serial RS232 port. I did come right though, a reboot of the Pi, and changing the setting to serial, and the Sunix Serial to USB cable started working, which really surprised me as it was quite fussy when I used it with a PC. Quote Link to comment Share on other sites More sharing options...
Chris Louw Posted January 11, 2020 Share Posted January 11, 2020 13 hours ago, viceroy said: This afternoon, I purchased ICC Pi V2, rushed home in order to install, and then remembered my Axpert MKS 4kW has a serial port... How do I connect it to the Pi? With the old AICC on PC, I used a serial to USB adaptor, but this doesn't work on the Pi. Any advice on what device might work? @vicroy Also had a problem with com's bord . The inverter was hit by lightning . The new inverter only had a USB connection and I needed a connection for my remote display . Removed the com's board from the old inverter and fitted it to the new inverter . Hope this info can help you . Quote Link to comment Share on other sites More sharing options...
Francois01 Posted May 30, 2021 Share Posted May 30, 2021 Can someone help. I have WatchPower installed on my laptop with windows10. The usb ports does not recognize the inverter device. All drivers from windows are up to date. I cant find a specific driver for Axpert inverters?? Please help. Quote Link to comment Share on other sites More sharing options...
