AXPERT 5000
Steve
Hi can anyone please help l have an AXpert 5000 and it doesn’t seem to charge from the grid when the batteries are flat also there are 2 inverters in a pair and one has ( S L ) in the middle of the screen at the top and the other has (H S ) or ( H 5 )  many thanks Steve
It would be your settings. Check settings 12, 13, 29 (ensure that setting 29 is at least 2.0 V less than setting 12). Also setting 16 should be SNU or CUt (might be called something different on your model, there are many Axpert 5 kVA models).
Quote
That's normal for paralleled inverters. One is a SLave, the other is the MaSter; they can't show an 'M' in 7 segments so they show a 'H' instead.
Hi thanks for taking time to answer il check tomorrow
Wouldnt snu charge at the same time thus reducing the pv production? Perhaps cso is the better option?
Just a thought.
Yes. Sorry, I rarely fiddle with the actual settings these days; Node Red does that for me, and uses more user-friendly terms.
11 hours ago, Fazil said:
What is node red?
https://nodered.org/
It's a graphics based way of writing code for Linux machines, aimed at instrumentation. It runs on a BeagleBone Black (similar to a Raspberry Pi).
Here is one of my screens, shrunk:
Edit: the above is all custom software, based on a home-made battery management system (LyteFyba). It doesn't come "out of the box" like that.
