Solar Harvest not corresponding
desiji
So i need a little bit of Enlighment, if i calculate correctly P=I.V which means if i calculat the PV voltage*Current i should get what i am maching in Watts but from the example if i do that i run short
P=87,4v*23A is 2010w but an pv watts i only see 1185w what are the grounds?
solar.thumb.PNG.c289704ea53285035eb7e43404dbdd74.PNGab
Depending on your make/type inverter, the following: ( seems like Axpert/similar)
They report PV a little different than your calculation:
Battery Voltage X PV Current = 1176W
They use the "post" mppt Amps and battery Voltage, If you had the pre-mppt amps it would work out the same.
