heelo,
i have 4kva ,48 v  offgrid inverter and due to high voltage  on ac side some spike ckt and other ckt board has been butnt. what is the alternative model of fb3307z transisitor as i couldnt find the exact match.
tyhank you
The full part number is IRFB3307Z; they might not have room on the part to legibly add the "IR". MOSFET part numbers obsolete pretty fast these days.
See this post for recommended replacement part numbers; both mentioned replacement parts still seem to be available. That post, and the one it updates, discuss the important parameters and how Weber selected the recommended replacements.
Edit: you should also heed the warnings about checking all the gate resistors and driver parts; these often fail when the MOSFET itself fails. Check the index of the linked topic (first post in the topic).
