Posted February 6, 20205 yr Kodak King 5Kw (Rebranded Voltronic Axpert) Pylontech us3000 No solar connected, backup only Hi all I have an issue with a brand new unit after installation while commissioning found to have no output voltage on output terminals yet display shows 230v in inverter mode and incoming line voltage 238v in bypass mode.Contacted supplier and went through all settings and they requested to remove the unit and return for repairs, unit was sent back and apparently they replaced the mother board.On reinstallation of the unit have exactly the same problem, any help would be greatly appreciated.
