Looking for a DC-DC  converter to get 5VDC from my 48 volt battery string.
This is to power a Raspberry Pi / Venus box.
I could use a regular 230VAC adaptor, but if the inverter shuts-down due to battery low-voltage, I lose the connection.
42 minutes ago, Crankshaft said:
Thanks, will check it out.
What concerns me is this:
"(Note: Higher than 50v can not work for a long time)"
I saw that. It is very strange wording - I think as long as you stay well below 3A, you should be fine. A raspberry pi 2 should not be a problem, but the option in the post above is better.
@Crankshaft I'm all for getting a cheapie rather than buying some expensive kit if the same can be done.
My concern here for your part is what happens if that DC-DC fails.
Many Voltage regulators will simply pass input through if they blow/fail. (Internal short circuit)
Lost a couple of pieces myself with the older LM3xx series. Luckily all during development phases, so no real biggies.
My concern if that happens you buy a new Pi which makes the Meanwell or even PULS seem fairly priced.
Alternatively maybe clipping with Zener or some quick protection circuit?
The older technology linear voltage regulators that you refer to could short but the switched mode DC-DC converters die with no output when they fail..
Mosfets like to fail short-circuit. In this case that would result in full power to the output.
  • 1 year later...
To get 5V from 48V
Use the above DC/DC from Communica (~R80.00) and get a 1.5KE6.8A Transzorb at the same time.    In its protection direction,  it has a ~7V voltage drop and can handle 400mA without getting to warm.   Wire it in serie in the postive 48V supply line, with the cathode band facing the 48V battery.
This drops the 48V  (can be up to 57V when charging), down to less than 50V.
Lastly put one of the RPI stick-on Heatsinks on the LM2596 chip to ensure it runs cooler.
Works great for a few extra sents
Edited by Randmental
Spelling
  • 1 year later...
Hey Crankshaft, i know i came some years late but, did you tryed the DIN rail DDR-15L-5? Did it work? I tried with a Buck Converter on PCB 60 to 5 VDC but it overheats (Same system 48V battery for a 5V PI), so im looking for a more robust option, the DIN one looks nice, but i dont have suppliers for that in my country, so im looking for comments before ordering something from outside (Because i will pay like double the cost just in shipping). Hope i can get an answer over here and thank you!
