1 hour ago, vulgrim said:
Grid Code Password for South Africa.
Your supplier is supposed to help you with that. I cant publish it , but have send it yo you in PM.
If you plan to change it because its failing the relay test, it would be better to rather look for the cause. If its failing the relay test, its because there really is a problem.
