Posted February 8, 20205 yr Good day I need assistance. My Pylontech battery is not charging and the Mecer inverter shows a bP error. What can be the issue? Edited February 8, 20205 yr by 705Lorna reason code looks like bP
February 8, 20205 yr Author Problem solved. Battery power went too low and the battery switched off. Reset the battery and problem solved.
February 9, 20205 yr 13 hours ago, 705Lorna said: shows a bP error "bP" is the "Battery not Present" error. That should have been the clue: the battery's BMS would have disconnected the battery due to too high or too low battery voltage.
January 14, 20223 yr How do I solve the BP error code. How do you rest the battery? Or how do I initiate my inverter to start charging again?
January 14, 20223 yr 5 hours ago, Jay-Dee Verster said: How do you rest the battery? You need to reset the battery. I don't own one, but I believe that you have to do a long press on a particular button or something. Different brands and sometimes different models require a different procedure to reset them. It's possible that the battery's BMS is damaged, such that it won't connect. But there are a lot of things to try before then. Perhaps someone happens to know the reset sequence for Pylontechs? But it may not be a Pylontech.
