Posted February 10, 20205 yr I have a question regarding interfacing a Voltronic (VOLTEX rebrand) Axpert 5kva inverter and Hubble 4,8kW lithium battery. Both units have RS232 ports, but no other points of commonality. I would prefer not to rely on voltage measuring alone from the inverter for SOC of the battery, so direct interface would be ideal. But as the battery seems to be relatively new on the market, I can not find much info in this. Would it be a safe bet to say that, if both devices have clearly marked ports as RS232, they would be able to communicate using this interface? Thanks
