Posted February 10, 20205 yr Hi I haven't used the 5KVa axpert inverters with the Shoto 48V 100Ah LiFePO4 before. I'm connecting two inverters in parallel with twon of these batteries in parallel My connection is from the batteries to the DC busbar then splits to supply the two inverters (I've fused the battery input to the invert with 63A fuse). Question: 1) What are the settings of program 02, 05, 12, 13, 26.27.29 and if there are others I should be aware of, please inform me. 2) What are the importance of earthing these batteries separate to AC DB earth 3) I've been told they perform better than the PylonTech, is that true? Regards Q
February 11, 20205 yr Hi, where did you get the shoto batteries from? price? I was offered on a few days ago but it was expensive
