February 12, 20205 yr I have it through the Grape Vine that the bulk of revov's sales is to people who want to use it in a Victron system, so they do care about being compatible. With that said, earlier batteries were not always compatible (it depends what BMS they shipped with it). I also heard, again through the Grape Vine, that they have a little converter unit that looks like a BMV to the Victron side (VE.Direct) that interfaces with the battery to provide SOC and other information. The easiest might be to simply ask Revov about the unit you have/want to buy.
February 13, 20205 yr I can't give much technical detail here, but I know that when I was quoted for my system there were two quotes and the difference came down to Revov or Victron. So from that I assume that the Revov batteries can be used with the Victron. Ask questions. The Revov distributors are very helpful.
March 4, 20205 yr My Victron Quattro and Revov are getting along nicely -small config issue on Revov BMS caused one reboot of system once - since it was changed no problems to date. I get 175Ah (@10% SOC) from 200Ah set - so close to 90%. On about 50 charge cycles - hopefully many many more to go
