Posted February 15, 20205 yr Due to the size of my flat the only place I can have the axpert mks2 inverter installed is on the wall in the lounge...not pretty. Is it possible to have a small cupboard mounted over it with the door having slatted ventilated louvers?
February 16, 20205 yr 11 hours ago, Ryanwb1 said: Is it possible to have a small cupboard mounted over it with the door having slatted ventilated louvers? That should be OK, as long as the air can flow quite freely. Those things generate a lot of heat, and you don't want them to get too hot if you can help it. You might not like the noise from the fans when the load and/or solar charging (if used) ramps up.
