I recently added an additional two pylontech batteries to my existing stack of four.
I noticed over the last few days that the charge jumps from 88% to 100% within a minute. The discharge seems fine though
This has been going on since i installed the new Batteries.
I added the batteries as specified ex:
1) Existing batteries should be around 80% charge
2) New batteries should be added to the top of the stack
3) Allow re-balance
The existing batteries was around 86% when i added the new stack, i believe the new batteries come charged at 80%. I am just worried that there might be something wrong with the new batteries, or there might be a system setup problem. I am Using Victron inverters, I've updated the settings to accommodate the new battery bank size.
oh... the batteries used are all Pylontech US2000's
Mine also does that little jump from 88% but it doesn't look like its just in 1 minute tho - closer to 20-30mins here
Also Victron - both a 3kva multiplus II + a 5kva looks like the same pattern
my batts are the pylontech 3.5kwh x 3
I also saw this sort of thing happening at the low end of the charge scale too.
Batteries got down to 21% and stayed there. I didn't wait more than 5 minutes to let it get to 20% so ICC could switch to grid and start charging. Would hate for this to happen to someone, and their batteries accidentally drain down to 0% because the BMS was still showing 21%.
I have since set my min battery switchover SOC to 25%.
