Posted February 25, 20205 yr Hi All, I have two 7.4 kWh Solar MD lithium batteries installed with a 5kVa Axpert MKS. At the weekend the inverter is now known as Axpert Ai in my control panel. Its was a bit eerie at first as the inverters settings have changed and it is making its own decisions and is dynamic. Its early days yet but the first tests seem to show an improvement in system efficiency. I can chat online at any time to the Solar MD guys from the control panel and I will publish some results. Well done Kayloyan and his team. Edited February 25, 20205 yr by Tony Swash add more photos
February 25, 20205 yr Author 5 hours ago, Tony Swash said: Hi All, I have two 7.4 kWh Solar MD lithium batteries installed with a 5kVa Axpert MKS. At the weekend the inverter is now known as Axpert Ai in my control panel. Its was a bit eerie at first as the inverters settings have changed and it is making its own decisions and is dynamic. Its early days yet but the first tests seem to show an improvement in system efficiency. I can chat online at any time to the Solar MD guys from the control panel and I will publish some results. Well done Kayloyan and his team. Edited February 25, 20205 yr by Tony Swash duplicate
February 25, 20205 yr Author It was an option offered to me by Solar MD. I didn't have to pay for it. Maybe they upload it to the batteries which then controls the inverter.
February 25, 20205 yr I think you have an old installation and they just activated it for you. My installation is from March 2019 - and it has been activated by the installer from day 1. It is similar to the smart inverters like Victron or SMA - where you can set how deep in % to discharge the battery. Also gives you the option to charge quick from the grid in case of load-shedding.
July 23, 20213 yr Hai i have axpert vm3 inverter do you guys know what the pin locations are so that it can talk to the v2 logger
