Anyone know if software like BatteryView is available for Dyness batteries, or any other way of checking cells and overall SOH?
  • 4 years later...
Hi I use primarily Solar Assistant with a proper cable and it reads properly each dyness battery https://solar-assistant.io/
Also Multisib does read the batteries separately http://www.multisibcontrol.net/
you see SoC, voltages, temperatures etc but not SOH, there was a software posted on this forum specifically for Dyness, but there if you have several batteries you need to check them one by one as the DIP settings differed to read them all through the Master one
