Posted March 5, 20205 yr Hi, I have recently installed a GoodWe ES inverter with a PylonTech battery. I do not yet have any panels attached to it and is used as a load shedding tool until I have added some panels. With the meter installed on the main grid input, it is able to give me a reading on the total draw from the grid. On the App and Website, I would like to be able to see where the power is going, eg) 1.2kW to the backup load and 2kW to the main load, but it appears to put these 2 together. What I would like to see is the backup load separated from the main load. Is that at all possible, and does the mode I have selected (Economical) make a difference? The reason that I have put it on Economical, is because when I put it on general, the battery did not seem to charge from the grid? Its not like the information is not there as the status screen does show the backup load. (pic2)
March 6, 20205 yr Author When i use the GoodWe software, I see the same image as the website. (pic1) I decided to look for other software, and I found an older version of the App, and although slightly less functionality, the view I wanted was there. Is there any way I can get this view on the website? Thanks
