5kW Mecer/Axpert + Pylon Batteries (Best battery monitoring??)
Hi,
I'm building a Off-Grid System.
Just for background... Currently I have 3x 5kW Mecer MKII with will be connected in Parallel. I also have 7x US3000 Pylon batteries and 48x 360W Canadian Solar modules.
From what I understand is that I will need an Raspberry ICC and battery monitoring cable etc... I also read stuff about the Victron BMV-702.
What is the best route to go to have the Inverter perform as it should....
Is there any significant gain for using a Victron BMV-702 if the pylons already have a BMS which supplies data through the ICC Pi?
Your input is appreciated.
Hi Paul,
Welcome
IMO As stated Pylontech BMS is enough no need for BMV
