MorneDJ Posted March 13, 2020 Share Posted March 13, 2020 I recently helped a friend to install his Axpert MKS-4kVA inverter, which is connected to 4x 200Ah batteries. The purpose was mainly to assist with load shedding, keep a few lights on. He however now want to add a number of solar panels, and I mentioned that the Victron MPPT's really does not like over-voltage conditions. He was looking at getting 6x 380W Seraphim Blade solar panels, connecting 3 in series, with the second string in parallel. The open circuit voltage is 48.3 V, and 3 in series will give a 144.9 V Voc. The booklet for the Inverter state: Max PV Array Open Circuit Voltage to be 145 Vdc. I assume that the builtin MPPT may release magic smoke if the voltage is exceeded. Would it be better to connect the 6 panels with 3 strings with 2 panels in series ? Could anyone recommend something better? Quote Link to comment Share on other sites More sharing options...
Coulomb Posted March 13, 2020 Share Posted March 13, 2020 7 hours ago, MorneDJ said: He was looking at getting 6x 380W Seraphim Blade solar panels, connecting 3 in series, with the second string in parallel. The open circuit voltage is 48.3 V, and 3 in series will give a 144.9 V Voc. And that's at 25°C. In cooler weather, the voltage will be even higher. You will get less than 1% of rated power at 144.9 V. 7 hours ago, MorneDJ said: I assume that the builtin MPPT may release magic smoke if the voltage is exceeded. I've not heard of it happening, but it certainly could. 7 hours ago, MorneDJ said: Would it be better to connect the 6 panels with 3 strings with 2 panels in series ? With these panels, definitely. Quote Link to comment Share on other sites More sharing options...
