Arc or Arc-free
Has anyone pulled and opened one of these fuse disconnectors while its under load, I would like to know when it draws some larger current, did it make an arc or are the design arc free?
1 hour ago, Gerrie said:
Arc or Arc-free
I accidentally pulled it open once under load, i thought the changeover switch was already flipped. it most certainly made a huge bang.
I suggest using it as it is intended to be used, as a fuse or for emergencies only (if you have no other emergency option).
Edited by stoic
It make sense to use it in emergencies only, It should than actually have a sign next to it stating “Do not open this link under load”
Inexperienced people could open it unknowingly and might cause a fire, I guess a circuit breaker would than be a better and safer option.
On 2020/04/02 at 4:59 PM, Gordon said:
Looks like a good solution for battery disconnect & not have to use a DC MCB, where can these units be acquired ?
These work fine, I use them on the bulk of my installations.
Have pulled them under load, did draw some arc, but if you yank it open fast, it reduces the arc a lot.
A DC breaker with ratings over 100Amp is really expensive, i have tried 2 different cheaper ones so far and both burned the points first time I opened them under load although they were rated for 500VDC, So if you want to use a breaker, look for a reputable moulded case breaker.
1 hour ago, FixAMess said:
Besides, in an emergency, turn the inverter off first, then throw the switch.
might be a problem if the inverter is on fire 🤣.
The problem is if a the wife or child has to switch off it becomes a problem. I was thinking when money is no problem then there are nice ABB breakers with a trip function on them that you wire to a emergency stop button. You fit the E/S at a accessible location and that will trip the ABB breaker. I’m just not sure if ABB make them in a DC breaker I know the AC ones are available.
This sounds like a really good idea..
