fuses blowing of 2000va inverter
21 hours ago, jeffreys chipunza said:
iam having 2000va ellis inverter, I used it for 2months the input fuse blew off I replaced it it was blown again
Did it work again (for a short while) after replacing the fuse, or did it blow again immediately?
The fuse may have blown the first time because something else is damaged, and if that is the case, replacement fuses will blow immediately every time. The fuse is there to ensure that in a fault condition (which includes damage in the inverter itself) nothing will set itself on fire.
 Share
