Wind Turbine with axpert inverter
Jannas
 Share
9 hours ago, Jannas said:
is there a possibilty to link a 5000w wind turbine on the system,?
I believe so. You'll need a separate wind power MPPT that connects directly to the battery. You might have to juggle the battery voltage parameters a bit so that the Axperts can get to float stage properly. Often that means setting the external MPPT battery settings (absorb/bulk/CV and float) to a little lower than the Axperts' equivalent settings.
 Share
