New member checkin- regulations
Good afternoon.
My apologies if this is Issue has been discussed. I have searched and do understand the issues around Cape Town regulations.
I stay in Tswane and note the draft bylaw has been floating around for a bit.  I have had no response on queries to the council.
All of municipal bylaws  are obviously  based on the  SSEG guidance for municipalities.  (NRS 097 2 1 dd 2017).  They seem heavily biased towards installations feeding power back into the grid.
Is my reading of these correct that a legal municipal installation, unless off-grid, is only possible on single phase capped at 4.6 Kva for the inverter?
Does this then imply that any inverter beyond that can only legally be used In off grid installations?
I am considering a Victron Quattro 8Kva or Multiplus 5 kva, with 12 Kwh Bluenova battery pack.  (9 Canadian solar 405 panels).  I dont intend to feed back into the grid, but would need grid on a AC in.
A fair number of installers seem nonchalant about the regulations, but I would not want to run into legal and insurance problems.
I would appreciate clarification on this topic. Can I legally install 5 kva+?
That's sort of what SSEG is about - small-scale embedded generation - installations tied into the grid
.That's the value for a single phase residence if you are on a 80A supply. If you're on a smaller supply, 60A, then it's limited to around 3.5. Anything higher needs to be on a 3-phase supply.
You said it.
 Share
