Axpert Inverter cutting out
gerritl
 Share
Good evening
I have an Acpert RCT 5K inverter (5kW/5kV) with 12 x 330W panels and 4x Vision HF12-890W  12V 200Ah batteries
The inverter was repaired under warranty on 3 March 2020. "Replaced the MPPT Charger PCB" was indicated on the Service POD note
Since then the Inverter has not operated the same as before. It will stop charging from the solar panels or switch to LINE mode unnecessarily as can be seen in the attached Watchpower screenprints.
I have also attached photos of the information sticker on the side and the home screen indicating the firmware version
Can anyone please advise me if the inverter can be reset in order to clear the "bug" or if a better firmware version is available and how to install this.
Regards
Gerrit
You could try resetting to factory default settings. But I suspect you have that already, as a result of the repair, and need to customise a few settings.
Can you post a photo of the configuration tab?
Is this what you need?
I forgot to mention, when the inverter stops charging from solar I need to change the Charger source priority to utility and back again to Solar only and then only will it start charging again. In the example I provided I caught it by chance and changed it back quickly. On previous occasions it would simply stay like that.
Edited by gerritl
That's good, thanks.
I would try reducing the battery cutoff voltage to 46 V temporarily, to see if that makes a difference to going to the grid or not. I think a fridge start or similar is dropping your battery voltage to under 49 V, which is less than 2.0 V above the battery cutoff voltage, and this triggers a switch to line mode (even though that setting is at 48 V).
Quote
Ok, that's sounding like the dreaded PV freeze that is affecting 2019 and later models (yours just squeaked in, lucky you 🙂 ).
I don't have an answer for that, though I got an idea today, which I may pursue over the next day or few.
I changed the battery cutoff to 46 V, thanks. Will keep an eye on it
Anxiously waiting to find out how to "unfreeze" my PV input :)
 Share
