Manfred Posted May 18, 2020 Share Posted May 18, 2020 Good day Power Forumers Have current setup of 2 x Axpert VMIII 5kW parallel connected inverters with 4 x 2.4 Pylon Tech batteries for use as UPS during load shedding. Single phase from utility in, single phase out. No PV connected. Question: Will it be possible to add a 3rd inverter to create a 3 phase output, but still only have the single phase utility input? Look forward to a way forward reply Regards Quote Link to comment Share on other sites More sharing options...
Coulomb Posted May 18, 2020 Share Posted May 18, 2020 33 minutes ago, Manfred said: Will it be possible to add a 3rd inverter to create a 3 phase output, but still only have the single phase utility input? I don't believe so, if you ever want to use the utility. If you could always use battery mode, you might be able to power a 3-phase load. Riyad179 1 Quote Link to comment Share on other sites More sharing options...
Manfred Posted May 23, 2020 Author Share Posted May 23, 2020 On 2020/05/18 at 11:05 AM, Coulomb said: I don't believe so, if you ever want to use the utility. If you could always use battery mode, you might be able to power a 3-phase load. Thanks Coulomb Quote Link to comment Share on other sites More sharing options...
