mr
Chris Olivier
 Share
Hi i am new to this forum , but would like to ask a question as to get more information.
i had to replace a older 4000 watt Highbrid solar inverter with a newer Expert 5000Watt/5KA  inverter the older inverter had automatic Equalizing setting but the new Expert inverter does not support or have this function .
the max voltage setting for charging on new inverter is 56,4 Volt /14,1 Volt per batt max will this be ok for Flooded batteries ,
or is there a other way of getting these batteries Equalized,
also i want to know is the Inverter manufacturer's forcing us to go to Gel/ pilot or other newer type batteries.
Thank you for your help
Chris
All Axpert models go to at least 58.4 V (14.6 V per nominally 12 V battery module).
Whether this is OK or not depends on your battery specifications; they vary enormously.
I'm surprised, if it really is a recent model. Settings around 30-36 relate to equalisation on recent models.
 Share
