GerhardK83 Posted May 25, 2020 Share Posted May 25, 2020 Hi All I trust that you are all well. I have the following questions regarding the Axpert King and Kodak King inverters. A] If I purchase the Kodak King inverters will I be able to use the Axpert parallel kit with the units or must I use a Kodak kit with the Kodak King inverters? B] What is the length of the Axpert parallel communication and the current sharing cables? C] Is there an easy way of solar panel grounding? Kind Regards GerhardK83 Quote Link to comment Share on other sites More sharing options...
Coulomb Posted May 26, 2020 Share Posted May 26, 2020 11 hours ago, GerhardK83 said: A] If I purchase the Kodak King inverters will I be able to use the Axpert parallel kit with the units or must I use a Kodak kit with the Kodak King inverters? I believe that they are the same thing, so they should be totally interchangeable. GerhardK83 and Riaanh 2 Quote Link to comment Share on other sites More sharing options...
Chris Louw Posted May 26, 2020 Share Posted May 26, 2020 The cables are 1.5 meters long . Pm me if u need boards or cables . GerhardK83 1 Quote Link to comment Share on other sites More sharing options...
GerhardK83 Posted May 26, 2020 Author Share Posted May 26, 2020 8 hours ago, Coulomb said: I believe that they are the same thing, so they should be totally interchangeable. Thanks for the feedback @Coulomb. Quote Link to comment Share on other sites More sharing options...
GerhardK83 Posted May 26, 2020 Author Share Posted May 26, 2020 3 hours ago, Chris Louw said: The cables are 1.5 meters long . Pm me if u need boards or cables . Thanks for the feedback @Chris Louw I will pm you shortly. Quote Link to comment Share on other sites More sharing options...
