Thank you for the great forum, Safe Driving over the weekend. Sincerely Jason
Halcyon
Help with Lithium battery?
Hi All
I have a Narada Lithium battery (48V 100ah) connected to a hybrid inverter.  It has been used for about a year and half now for load shedding backup purposes.  In the last 3/4 months I have noticed the SOC on the batteries own internal BMS screen is gradually dropping down even-though the float voltage is maintained correctly as per specification. It drops about a 1% a week.  The manual states 51,75V for float and 54V for charge
I tried a test discharge a while back all the way down to cutt-off voltage and that did reset the SOC back to 100% upon recharge, however subsequently it started gradually dropping down again and is on 89% at present.   The latest discharge and charge cycles have not worked to reset SOC back to 100%
What is going on?  Should I be worried? Time for a warranty claim?
Share this post
Link to post
Posted (edited)
Hi,
How many cycles on the battery?
My 100AH Pylontech bank is dropping 0.1% capacity for every 10 cycles.
So after about a year and a half and 120 cycles the remaining capacity is now 98.8AH.
I searched the datasheet for the Narada but it doesn't mention anything about cycle life.
What is the warranty period on the battery?
I am no expert but sounds like it is degrading rapidly.
Edited by francois
Share this post
Link to post
Hi Francois
It is on 110 cycles at the moment and is about 1,5 year old. It has a 10 warranty period to my knowledge.  Spec sheet sais "more than 3500 cycles at 100% DOD", but mine has never gone that low.  Normally around 60% or higher during load shedding.  I think on 80% DOD or less it should have a life of 4/5 thousand cycles.  Mine has a 92,4Ah remaining which does seem like a fast degradation to me.  I will get in contact with the supplier
Share this post
Link to post
