Bond Neutral and Earth on Growatt SPF 5000TL HVM
jykenmynie
 Share
3 minutes ago, ZorbatheGeek said:
OK noted Johandup ... more questions in my head now:
  • Are the Infinisolar and Growatt based on the same platform?
  • How do you keep the neutrals separate if the inverter feeds to the main DB eventually? Should the inverter then have its own grounding, separate to the grid supply, and inverter neutral is then bonded to this?
  • But then when the internal changeover switches to grid output will it use both inverter and grid neutral/ground? (any problem with this?)
No idea
 Share
