GerhardK83 Posted June 18, 2020 Share Posted June 18, 2020 Hi All I trust that you are all well. I have the following questions regarding the cable thickness and lugs size supported by the Axpert King 5Kva unit, the book is not clear in this regard. A] What is the maximum size of cable supported by the AC In connector block? B] What is the maximum size of cable supported by the AC Out connector block? C] According to the book the battery connections are made by lugs but they do not specify how thick the bolt is that is used to hold the lug in place, so I want to know how thick is the bolt that holds the lugs in place? D] What is the maximum size of cable supported by the Solar In connector block? E] How long must the wires be stripped for the AC In connector block to make good contact in the connector block? F] How long must the wires be stripped for the AC Out connector block to make good contact in the connector block? G] How long must the wires be stripped for the Solar In connector block to make good contact in the connector block? Kind Regards GerhardK83 Quote Link to comment Share on other sites More sharing options...
Coulomb Posted June 18, 2020 Share Posted June 18, 2020 I don't own a King, but I think you'll find answers to most of your questions in the user manual. If you don't have one, get one from here: http://mppsolar.com/manual/PIP-MK (PF1.0)/ Quote Link to comment Share on other sites More sharing options...
