Andrewj Posted July 19, 2020 Share Posted July 19, 2020 Hi just installed new vmii king less than a week ago. Excited about the upgrade from the old 4k unit. My problem is the fan runs full speed continuously. If I switch the unit off and on the fan ramps up and stops but in about 30min it is running flat out again. This is with very little load on. This is not normal right? Is there a fix? Quote Link to comment Share on other sites More sharing options...
Coulomb Posted July 20, 2020 Share Posted July 20, 2020 9 hours ago, Andrewj said: Hi just installed new vmii king less than a week ago. The Axpert VM III is a different model to the Axpert King. The King has zero transfer, and is parallelable to 9 units; the VM III has neither. 9 hours ago, Andrewj said: If I switch the unit off and on the fan ramps up and stops but in about 30min it is running flat out again. I assume you have a VM III then. This is a "value line" model, and one of the areas of cost cutting seems to be the control of the fans. One of them seems to be on/off only; the other seems to be able to be speed controlled, but only under certain conditions. I know very little about the VM III model. Perhaps other owners could chip in with their experiences. Quote Link to comment Share on other sites More sharing options...
Andrewj Posted July 21, 2020 Author Share Posted July 21, 2020 Hi Coulomb, thanks for your reply, that is correct it is a vm3 not a king. It does seem to ramp up the fan when first the inverter is turned on. It ramps up the fan, then slows down and stops, then in a in about 20-30min it starts again and then runs flat out continuously. Is that normal then? Quote Link to comment Share on other sites More sharing options...
Coulomb Posted July 21, 2020 Share Posted July 21, 2020 2 hours ago, Andrewj said: Is that normal then? Other VM III users would have to comment; I have no idea. Quote Link to comment Share on other sites More sharing options...
JaseZA Posted August 2, 2020 Share Posted August 2, 2020 Here is my reply to another thread about the fans on my VMiii: Fan turns on when temp hits 42°C, solar power is greater than ~500W or battery is charging/discharging around ~500W. So not always, but fairly often. Quote Link to comment Share on other sites More sharing options...
Andrewj Posted August 2, 2020 Author Share Posted August 2, 2020 Thanks, there must be something wrong with mine then. It seems to be fine until there is a load that ramps it up, and then for some reason it runs continually. Wonder if it is a firmware problem or a hardware problem? Does anybody have a firmware update for vmiii or know were I can get it? Quote Link to comment Share on other sites More sharing options...
data Posted September 5, 2020 Share Posted September 5, 2020 Which firmware version do you have? I've had the same issues with the fans and solved it by upgrading with attached files. The most recent Version I have is main-CPU 41.07 and bluetooth 00000.21 Attached you'll find the firmware archive along with the necessary installer for windows. I did the MCU upgrade first, after that the control panel. Use a good serial to usb converter. Some cheap ones do not work! When upgrading, keep in mind that the converter shuts off the power towards the end of the upload. So always use a notbook with charged batteries, otherwise your upgrade will fail and you'll have to debrick the unit... @coulomb pointed me to some posts where you can see a more recent version (41.14 and 0.24), so if anyone here has a more recent version, please upload it or send it to me. GK fan spin program.zip Coulomb 1 Quote Link to comment Share on other sites More sharing options...
Andrewj Posted September 6, 2020 Author Share Posted September 6, 2020 Hi Data, great thanks for the info, will try it today, will let you know what the outcome is. Did check the version current U1 41 14 Also have some more info, after a few cloudy days, it hasnt done it. (Have and external microcare mppt, not using the build in mppt.Bulk charge is set to 60V as my flooded lead acid is nearing the end.) Noticed it seems that when battery bulk charge reached over 58v the fan starts running and then does not turn off again. Maybe the other firmware will work better. Quote Link to comment Share on other sites More sharing options...
Coulomb Posted September 6, 2020 Share Posted September 6, 2020 6 hours ago, Andrewj said: Did check the version current U1 41 14 I note that the GK fan spin program zip file above contains U1 version 41.07, i.e. earlier than what you have now. I also note that there is no way to get back to 41.14 if you flash it to 41.07. It also contains a fairly old removable display firmware, version 02.08. That's also likely considerably earlier than the one you have now, although that one you can probably update, since it's the same as the Axpert King removable display firmware, and several versions of those are available, up to 02.49. So I don't recommend you downgrading to that firmware. Quote Link to comment Share on other sites More sharing options...
data Posted September 6, 2020 Share Posted September 6, 2020 (edited) @andrewj When did you buy your GK? And what version is your control panel / U2? Edited September 6, 2020 by data Quote Link to comment Share on other sites More sharing options...
Andrewj Posted September 7, 2020 Author Share Posted September 7, 2020 Bought it about 3 months ago. U2 02 40 U3 00 24 Quote Link to comment Share on other sites More sharing options...
palagarde Posted October 26, 2020 Share Posted October 26, 2020 Same problem for me, VMIII bought in october, very noisy fans run full speed continuously, firmware U1 41.15, U2 2.40, U3 00.24. Quote Link to comment Share on other sites More sharing options...
palagarde Posted November 1, 2020 Share Posted November 1, 2020 small update, I have a second VMIII with firmware U1 41.19 U2 2.65 and fans are working normally (run only if AC load and speed depend of load). Quote Link to comment Share on other sites More sharing options...
epromise Posted December 2, 2020 Share Posted December 2, 2020 Where did you get the 41.19 and 2.65 and can you provide us with the link? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
epromise Posted December 2, 2020 Share Posted December 2, 2020 On 2020/11/01 at 11:15 PM, palagarde said: small update, I have a second VMIII with firmware U1 41.19 U2 2.65 and fans are working normally (run only if AC load and speed depend of load). Where did you get the 41.19 and 2.65 and can you provide us with the link? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
palagarde Posted December 2, 2020 Share Posted December 2, 2020 Sorry, I don't have the firmware. The inverter came with it installed. I bought it on rebacas.com Quote Link to comment Share on other sites More sharing options...
serafino Posted January 1, 2021 Share Posted January 1, 2021 il mio VMIII le ventole funzionano normalmente si attivano solo se ce un assorbimento la velocità dipendono dal carico e dal 2018 che l'ho installato Quote Link to comment Share on other sites More sharing options...
Juan Yves Posted January 2, 2021 Share Posted January 2, 2021 (edited) I got the same problem than Andrewj and same version (U1-41.15 U2-2.40 U3-0.24) Axpert VIII 5kva Where is it possible to get firmware 41.19-2.65 or more recent? It should be possible to do a backup on a new machine and post it. Thanks in advance Edited January 2, 2021 by Juan Yves Syntax Quote Link to comment Share on other sites More sharing options...
Coulomb Posted January 3, 2021 Share Posted January 3, 2021 On 2021/01/02 at 4:35 AM, serafino said: il mio VMIII le ventole funzionano normalmente si attivano solo se ce un assorbimento la velocità dipendono dal carico e dal 2018 che l'ho installato Google Translate: my VMIII the fans work normally they are activated only if there is an absorption the speed depends on the load and on 2018 that I installed it OK, but what version of main (U1) firmware are you running? It's possible that only firmware in a certain range has the problem. Quote Link to comment Share on other sites More sharing options...
Coulomb Posted January 3, 2021 Share Posted January 3, 2021 17 hours ago, Juan Yves said: Where is it possible to get firmware 41.19-2.65 or more recent? I haven't gotten around to uploading it. It's available from this site in the Czech Republic: https://www.ostrovni-elektrarny.cz/support/Axpert/FW/ (last few entries pertain to VM III models). Quote It should be possible to do a backup on a new machine and post it. It's not possible to extract existing firmware from an inverter. To do it, you would need slightly specialised equipment and software, not too hard, but also a security number (a string of some 32 hex digits). I'm not aware of that security number being available anywhere. The manufacturer wants to keep it that way, so that clone makers can't easily steal their firmware to use in their competing products, without having the very considerable development expense. Quote Link to comment Share on other sites More sharing options...
Andrewj Posted January 4, 2021 Author Share Posted January 4, 2021 Thanks Coulomb for the link, downloaded and updated the firmware, so far so good. Great, I am very pleased Quote Link to comment Share on other sites More sharing options...
mariusvaida Posted November 23, 2023 Share Posted November 23, 2023 Hello everyone, i just want to thank you for this topic, my inverter also have this issue and despite it is brandes like PowMR (Model 5KW III) , this version (41.17) works fine and fixes the fan problem. Coulomb 1 Quote Link to comment Share on other sites More sharing options...
