GordonT Posted July 25, 2020 Share Posted July 25, 2020 Good Day Guys I am new to the inverter world so if questions are a bit boring to the more experienced I apologise. I own a Axpert 3Kva 24 volt Inverter and my questions are: 1. Does this axpert come with a built in change over switch. 2. Is there any reason that i need to add a second change over switch when this unit is connected to a db board. 3. I have 2 X 12v AGM 100amp batteries connect in series what size battery fuse should I use. Many thanks in advance GordonT Quote Link to comment Share on other sites More sharing options...
Coulomb Posted July 26, 2020 Share Posted July 26, 2020 12 hours ago, GordonT said: 1. Does this axpert come with a built in change over switch. Yes, all the Axperts do. 12 hours ago, GordonT said: 2. Is there any reason that i need to add a second change over switch when this unit is connected to a db board. Yes, for maintenance and if there is a fault. You could get away without one, but it would be a good idea. 12 hours ago, GordonT said: 3. I have 2 X 12v AGM 100amp batteries connect in series what size battery fuse should I use. Those will be 100 Ah batteries; Ah measures energy. I suggest a 125 A DC rated fuse. SYC 1 Quote Link to comment Share on other sites More sharing options...
GordonT Posted July 26, 2020 Author Share Posted July 26, 2020 Many thanks for the feed back .......Much Appreciated Quote Link to comment Share on other sites More sharing options...
