Maboho Posted April 5, 2021 Share Posted April 5, 2021 I installed a kodak 5kw off grid inverter with a polytech us3000 battery but the inverter doesnt charge the battery nor does it shows the solar panels ... but the is 148vdc coming from the panels Quote Link to comment Share on other sites More sharing options...
Jannie Viljoen Posted June 22, 2021 Share Posted June 22, 2021 Where can I buy the "ICC software and Pi"? Members 126 Posted August 22, 2020 I have this inverter and Pylontech battery. I honestly recommend using the ICC software + Pi to manage communications between battery and inverter. It allows you to also setup / change a bunch of things remotely and not need to go to the inverter. Quote Link to comment Share on other sites More sharing options...
Coenie de Roubaix Posted June 6, 2022 Share Posted June 6, 2022 Initial installation: Is it necessary to load the software from the disk supplied or is it only necessary to do the settings on the inverter and install the RS232 cable between the inverter and the Pyloteck battery. Coenie de Roubaix Mobile: +27[0]829903029 email: [email protected] Quote Link to comment Share on other sites More sharing options...
