Iaan de Wet Posted August 15, 2020 Posted August 15, 2020 Axpert 5kw Hybrid and Kodak 3.6Kw grid tie can it be AC Coupled ? Good day, I have the above systems thatbi have installed myself, each with 4.2kwp pv installed but operating separately. Is it possible to run these two systems together in a AC coupled system ? Quote
Jaco De Jongh Posted August 15, 2020 Posted August 15, 2020 1 hour ago, Iaan de Wet said: Is it possible to run these two systems together in a AC coupled system ? If you mean, can you parallel them, the answer is no. Paralleled units must be identical in model and size.. Rclegg 1 Quote
gooseberry Posted August 16, 2020 Posted August 16, 2020 I think you'd have to add the grid tie inverter on the grid side. AFAIK Axperts don't support frequency shifting, which is what you'd need for this to work. Quote
