RichardC Posted August 17, 2020 Posted August 17, 2020 Good Evening, I have a question regarding hybrid inverters specifically SunSynk 8kW. If you have (for example) 7kW load on the backup output during the day and 2 geysers (call it 6kW) up stream on-grid, will 1 kW excess PV be supplied to the geysers without overloading the inverter? Assuming the wiring is correct with CT in the correct place Quote
Achmat Posted August 17, 2020 Posted August 17, 2020 1 minute ago, RichardC said: Good Evening, I have a question regarding hybrid inverters specifically SunSynk 8kW. If you have (for example) 7kW load on the backup output during the day and 2 geysers (call it 6kW) up stream on-grid, will 1 kW excess PV be supplied to the geysers without overloading the inverter? Assuming the wiring is correct with CT in the correct place Yes. If you set the inverter to limited to home mode, excess PV will go to loads before the inverter. I have the 8kw sunsynk inverter and it will do this with excess PV up to the total max 8kw that the inverter can put out. francois and RichardC 2 Quote
