Shadders 17 Posted October 22, 2020 Share Posted October 22, 2020 When connecting to inverters you use pin 1 (RS485B) and pin 2 (RS485A) on the pylontech side RJ45. What RS485 converter are you using to connect to your PC USB? Quote Link to post Share on other sites
R Cerva 3 Posted October 22, 2020 Share Posted October 22, 2020 Hi. According to pylontech manual pin 1 and 8 are the same, Pin 2 and 7 the same. They recommend using 6 -grd, 7 - RS485A and 8 - RS485B. Will change connector to see if any change. I'm using usb to serial convertor that I use with all my softwares for PLC programming and have no hassles. Some PLC's have issues if convertor not good. On the 9 pin plug what must the connection be. Thanks Quote Link to post Share on other sites
Shadders 17 Posted October 22, 2020 Share Posted October 22, 2020 (edited) 2 hours ago, R Cerva said: On the 9 pin plug what must the connection be. The modbus standard specifies pins 5 (A) and 9 (B) https://www.modbus.org/docs/Modbus_over_serial_line_V1_02.pdf Edited October 22, 2020 by Shadders Incorrect information originally Quote Link to post Share on other sites
R Cerva 3 Posted October 22, 2020 Share Posted October 22, 2020 Thanks. Will make cable and test tomorrow. Quote Link to post Share on other sites
MarcB2007 0 Posted November 12, 2020 Share Posted November 12, 2020 Hi yani, i have one 4048MSD monitored by ICC, one EASUN SMK (~Axpert King) monitored by solpiplog and one PCM60X battery charger monitored by a small tool. Is it possible to monitor the PCM60X with your program as well? It would be great to combine my 3 systems and monitor/control it by one software. Quote Link to post Share on other sites
Warlok 8 Posted November 12, 2020 Share Posted November 12, 2020 Hi @yani Really nice software. One question, is there a way to get it to switch to solar at 07:00 and grid at 16:00? I'm using agm batteries and the switch to grid or battery does not work. I assume the switch only works when you have Pylons connected, or is there a way to do it while having the agm's connected? Quote Link to post Share on other sites
Xman 0 Posted November 24, 2020 Share Posted November 24, 2020 Hi, I did make a serial cable for the console port on the Pylontech U3000 that plugs into a USB to RS232 convertor. Images to make the cable are in an earlier post. At first I could not get it to work. Checking on this forum and in the pylontech manual I found on this forum the baud rate of the USB to serial must be set to 1200 in windows. I hope this info helps the next guy trying to connect the Pylontech through the console port. It all works 100%. This is really great software Quote Link to post Share on other sites
Newbie 1 Posted December 19, 2020 Share Posted December 19, 2020 @Xman. May you kindly share the schematic diagram for the cables please if you don't mind. I am planning to build one for my unit as well .. Many thanks Quote Link to post Share on other sites
Xman 0 Posted December 23, 2020 Share Posted December 23, 2020 On 2020/12/19 at 5:02 PM, Newbie said: @Xman. May you kindly share the schematic diagram for the cables please if you don't mind. I am planning to build one for my unit as well .. Many thanks This is the diagram I used I used one of these connectors below. I had a old phone cable with the 4 wires and I crimped a rj45 on the one end so I did not need to solder the connector https://www.comx-computers.co.za/ADA023-Unbranded-RS232-9-pin-Female-Serial-to-RJ45-Buy-p-171417.php Hope this helps Quote Link to post Share on other sites
Xman 0 Posted December 23, 2020 Share Posted December 23, 2020 On 2020/12/19 at 5:02 PM, Newbie said: @Xman. May you kindly share the schematic diagram for the cables please if you don't mind. I am planning to build one for my unit as well .. Many thanks You get a connector like as well this is you want to avoid soldering https://www.comx-computers.co.za/DELOCK-65268-Delock-9-pin-Sub-d-F-Terminal-Block-Buy-p-173531.php Quote Link to post Share on other sites
Richard Mackay 116 Posted December 23, 2020 Share Posted December 23, 2020 1 hour ago, Xman said: You get a connector like as well this is you want to avoid soldering https://www.comx-computers.co.za/DELOCK-65268-Delock-9-pin-Sub-d-F-Terminal-Block-Buy-p-173531.php The sub D 9 pin plug is fairly easy to solder the wires onto.. Quote Link to post Share on other sites
TjObie 0 Posted February 15 Share Posted February 15 Hi Everybody I installed this software with a Axpert MAX 7.2 and had a problem reading the second PV string. I contacted Yani yesterday and today he send me a updated version of the software. Excellent service for a Free version of software. So once more, many thanks to Yani for the quick response. Your software looks great and works well now. Tj Quote Link to post Share on other sites
R Cerva 3 Posted February 15 Share Posted February 15 Hi. Glad to hear you got reply. Send several emails with no reply. I've upgraded my invertor to 8kw deye invertors. Asked if the software support it but no reply. Quote Link to post Share on other sites
Denarius 12 Posted March 3 Share Posted March 3 @R Cerva You can use solar assistant for Deye/SunSynk. As far as I know multisib doesn't support SunSynk. https://solar-assistant.io/ Quote Link to post Share on other sites
Doug72 0 Posted March 5 Share Posted March 5 Hi All, So, firstly, can MultiSIB control be run from a Pi? Because I don't want to tie up my laptop monitoring my inverter. And then secondly, is there a way of linking it to my MCB to turn off, for example, the pool pump when the battery (Pylontech) SOC drops below a certain level, and turn it back on again when it climbs back up again? Many thanks Quote Link to post Share on other sites
ShaunKZN 1 Posted April 6 Share Posted April 6 Hi all Tested Multisibcontrol on Windows 10 laptop. Picked up my Mercer MKII's(Parallel setup) but at first could not see my 4 Pylontechs(US3000c). I made up my RJ45 to Serial(Diagrams attached) , plugged it into console port of master battery and used a regular serial to usb cable to connect it to the USB port on my laptop. After plugging and removing a few times it still didn't work. I then opened Device Manager on windows 10 , plugged in the usb/serial cable again and saw a little ! indicating incorrect drivers of the new device. I clicked on properties / update driver / windows recommended search from internet. The CH340 driver was installed(same as arduino drivers I think). Once installed I unplugged the usb/serial and plugged it back in opened Multisibcontrol. After a few seconds it detected all 4 Pylontechs and showed all parameters. I did not have to change Baud rate settings. I plan on using an old laptop and chrome remote desktop to mirror the desktop onto my computer and work or onto my phone for now. Quote Link to post Share on other sites
azharc 0 Posted 10 hours ago Share Posted 10 hours ago Has anyone got any examples of the Device Control setup? Is it possible to check the Pylontech's SOC% is > 95% at 17h00, if NOT then change Output Source Priority to SUB. Once the SOC% is > 95% then change Output Source Priority to SBU. If there is another way to do this please advice me. Quote Link to post Share on other sites
Denarius 12 Posted 10 hours ago Share Posted 10 hours ago 12 minutes ago, azharc said: If there is another way to do this please advice me. I do that with solar assistant https://solar-assistant.io/help/power-management/axpert Quote Link to post Share on other sites
