Axpert/Pylontech /Raspberry pi.
Now on my third axpert inverter in a week, first had out of box failure, second had coms failure, now on number three and keeping fingers crossed.
if i am monitoring with icc software do i still need to connect the coms cable that comes with the pylontech between the pylontech and the inverter?
Which Axpert model do you have? Most cannot talk directly to a Pylon BMS, so that cable would not help you much...
If you have ICC and also the comms cable to connect the Pylon to your Pi (and everything is set up correctly), then there is no need for a direct connection between your inverter and the Pylon
