Etiennet Posted August 24, 2020 Share Posted August 24, 2020 (edited) Good day Gents, My inverters USB port on the display got damage. Can a replacement be bought or would I be able to fix it? Edited August 24, 2020 by Etiennet Quote Link to comment Share on other sites More sharing options...
Coulomb Posted August 25, 2020 Share Posted August 25, 2020 18 hours ago, Etiennet said: would I be able to fix it? It should not be too hard to replace the (presumably) surface mount USB connector, if your'e at all handy with soldering. Assuming that the problem is mechanical. If it was some sort of electrical overload, that's a totally different situation. You might be able to order a replacement removable display from your supplier, or possibly from eBay or similar. But I'd worry about compatibility if it doesn't come from your supplier. Quote Link to comment Share on other sites More sharing options...
Etiennet Posted August 25, 2020 Author Share Posted August 25, 2020 Thanks coulomb, Basically, the port got damaged when I tried to move the inverter. The actual plug broke off inside the removable Display unit. Quote Link to comment Share on other sites More sharing options...
