September 7, 20205 yr Here is my King installation. not complete!. I need to wait for payday and get battery fuses and more panels
September 9, 20205 yr 8 hours ago, DaveSA said: If they are 72 cell 330W panels you going to be back here soon complaining about loss of PV. You need to wire 2 panels in series per string. 3 in series makes the Input Voltage higher than the MPPT limit of 115V @CliveS
September 9, 20205 yr Author 1 minute ago, CliveS said: Thanks Guys. I've got them back here later this week to fix this issue. Hi, Clive You have the same issue?
September 9, 20205 yr Hi Barry, Yes, my issue is that the PV cuts around 11am and starts up again around 2pm.
September 9, 20205 yr Author 1 minute ago, CliveS said: Hi Barry, Yes, my issue is that the PV cuts around 11am and starts up again around 2pm. same inverter? King 5KVA
September 11, 20205 yr Author So I have change my system toe 2S2P. watts is still low, will need to move the panels to get the angel correct.
